Ignition fuse keeps blowing instantly on Bayliner w/ Mercruiser 5.7
CLi87
Hey all,
I just did the engine coupler on my Bayliner 2050 w/ Mercruiser 5.7 and Alpha One, I didn't remove the engine, I just disconnected it and supported it while moving it 6 inches forward to get to the coupler. In the process I'm pretty sure I only removed the 3 ground wires that attached to the bell housing bolt and the main harness connector, I reconnected everything and now my 20 amp ignition fuse keeps popping instantly the second I turn the key, but everything else works, trim, bilge, blower, etc...I checked the wiring diagram and it shows all the grounds go directly to that bell housing ground bolt. Am I missing another ground somewhere?
CLi87
Engine serial 0K035890
Transom setial 0K137078
Tx, want o see if you have an electric fuel pump
When moving the motor forward to replace coupler the Alternator connections may have been damaged or wire chaffed. One is the purple ignition wire
Also look in this location where the chain was connected, along with the 10 pin connector
CLi87
I do have an electric fuel pump, I'll check those connections now, also, engine turns over when power probing
CLi87
Also if i disconnect the purple/blue yellow wire from the ignition switch the engine will turn overvfine
Have not seen those colors on the ignition switch
Red/Purple = main power
Purple = Ignition
Yellow/Red = Start
CLi87
Found the issue, the purple wire end was touching the support bar for the power steering cooler -.-
