Hello,
I just bought a 1998 Four Winns Horizon QX with a Volvo Penta 4.3 and it tends to blow ignition fuses sporatically and only when I turn the key to start the engine. I can hear the starter click and then nothing because the fuse is blown. I have looked at the wires under the dash and in the engine compartment and they all look nice and clean. Could this be the starter and how can I test this? Also if I use a 15amp fuse it seems to work but I obviously would like to get a 10amp working since that is what is supposed to be used for the ignition.
Thanks! Mike
Thanks! Mike
