scout-j-m
- Joined
- Jul 31, 2009
- 642
My ignition key switch has gone bad on my 1994 70hp Force. I think the push-to-choke feature had gone bad as well as the spring action that returned it from start position to the run position. To top it off when I removed the switch and leads to clean everything up with a wire brush the main power terminal for the battery wire broke off.
The only replacement part I have found so far is the Mercury/Quicksilver switch F5H268. It seems to range from $40-50. I was just wondering if there are any alternatives or if I should just go with this part. Thanks.
