Ignition Module
Can anyone tell me what the Ignition Module does, If it needs to be grounded to the block and where it is supposed to be mounted on an 88 gm 4.3L omc. I am baffled.. cant find anyplace to mount it. Thanks
bruceb58
Re: Ignition Module
An 88 OMC does not come with an ignition module. It comes with a points type ignition system.
Re: Ignition Module
Ok.. maybe I am calling it by the wrong name.. I will take a picture of it and post it up later.. thanks!
bruceb58
Re: Ignition Module
If you are referring to the ESA, it mounts to a bracket near the shift cable bracket.
