Any advice you guys have would be great!
My boat runs great at all speeds/RPMs for the first 35-40 minutes, but once my engine is warmed up well it will not run between 1200 and 2500 rpm. If I can get it above 2500 it still runs like a charm. At idle it runs fine too.
It does this both when throttling up or down. If it's at 3000 and I slowly lower RPM it will begin cutting out until the throttle position is nearly to idle. Then it smoothes out again. It does this whether or not it is under load (in gear on the water or on a hose in neutral). Also of interest, the tach goes crazy and the voltage drops by 2-3 volts in this "bad" RPM range.
One strange additional clue that I discovered by accident is that when I'm throttling up if I tap the trim in the "up" direction for a fraction of a second, it will grab and rev up.
Here are the vital stats:
'84 Mercruiser 350ci 260hp
Thunderbolt electronic ignition system
New plugs, wires, cap, rotor
Fuel separator checked, no water in fuel, only a few small specs of junk
Rochester 4-barrel carb
So here is my thinking:
The fact that it starts acting up once hot, and since adjusting the trim (also an electrical system) affects it, makes me think it's electrical. Does this point to the coil or is there something else I should be looking at first?
I tend to think it isn't fuel related since it runs great at higher RPM, and it seems like if it were an accelerator pump problem it would not happen on deceleration. Could the choke have anything to do with this? That's the only thing I know of that changes after about 30-40 minutes related to the carb.
Seems like these symptoms/factors should point fairly clearly to something, but I don't know enough to know what. I've looked through the adults only section and a number or related posts, but couldn't find anything that seemed to match my situation.
What do you guys think? Thanks in advance!
