Ignition problem on mercruiser 3.0L?
pmgrape
I have a 1988 mercruiser 3.0L. I tried starting it for the first time since my local marina winterized it last winter. Needless to say it wouldn't start. I saw good fuel flowing into the carb. and could even smell gas when she became flooded. <br />I have a breaker point ingition system. I went through checking plug and coil wires, making sure they were connected. I cleaned the plugs, even though they were brand new with the winterization. I read in my Clymer manual to check the coil for spark by removing it from the distributor and holding it 1/2" from a ground( I used a bolt on my engines head) and cranking the engine. No spark. I took the coil to a local auto parts store and he tested resistance and told me it was fine. Distributor cap looks good and I cleaned contacts. Points look brand new and properly set.<br />I'm stumped. Could it be the condenser, which I replaced last spring? Could the coil still be the culprit, and if so how do I test it? Could it be plug and/or coil wires, and if so is there a way check them without replacing them?<br />The engine turns over great and I have a brand new West Marine duel purpose battery.<br />Any help would be greatly appreciated.<br />Thank you <br />Brian
pmgrape
Re: Ignition problem on mercruiser 3.0L?
I almost forgot, would it be worth my time to replace my ingition system with the electronic system my local parts guy showed me( I believe it costs about $100), and if I bought this kit, how hard is it to install?<br />Thanks again<br />Brian
snapperbait
I would start by verifying with a volt meter, that you have voltage to the positive terminal of the coil with the ignition in the "on" position.. Should be about 10.5 volts at the coil..
pmgrape
I checked with my multimeter and do have voltage on to the coil. About 11 volts
The Ele. Conv. is the way to Go.... <br />Remove the points,+ condenser... Put the ele. trigger in,+ your ready to go..... Very Easy Swap...<br />Do you have power to the points ???<br />If you power the coil, then ground it out, It'll fire...
