jathomps04
- Joined
- Apr 23, 2003
- 27
Ok. I've been working on this motor for some time. I have a 1981 40HP Mercury Outboard. Two cylinder, automatic start. I finally was able to start it yesterday. As I was adjusting the idle and letting the gunk run out of the carb the engine suddenly stopped. After looking around for a bit I noticed that a black and white wire that runs underneith the flywheel had gotten caught in the flywheel and was cut in half. I quickly replaced the wire and now still do not get any fire. <br /><br />Does anyone know what this could be? Should I try and pull the flywheel and check to see how the wires look under there?<br /><br />P.S. The Black/White wire that broke was run underneath the firewall with another wire that, if I remember correctly, was black/yellow but possibly brown/yellow.
