ignition problems with colorcoding
I have a 1990 Sunbird boat with a 1990 90hp Johnson Motor. I am trying to install a new ignition key switch push choke. I need the color codes. I no longer have my manual. Any help will be greatly appreciated.
Dhadley
Re: ignition problems with colorcoding
The terminals are marked on the switch. Just change one wire at a time. Or you can order a service manual and the wiring diagram will be in there. Don't forget to disconnect the battery before you start.
thanks Dhadley for the info, we finally got it wired. thanks again for your help.
