Ignition Resistor Query
pcmpete
Engine is a Ford 302 marine, I replaced the coil resistor because i was getting battery voltage coming OFF the resistor which had 2.0 ohm resistance with a new resistor (from auto part store for the 302) which is only giving me 2.74 volts OUT from the resistor and with 3.3 ohms resistance.
What should the output voltage from resistor be and what is the resistance?
Thanks
