Ignition Switch, 86 Bayliner/125hp Force
SwampThing
Would anyone happen to know which switch I would need to order to replace the OEM switch? Looking through the catalog here gets confusing as heck. Couldn't find a part number to cross reference it with, old switch only says "Indak" on the back side with no part numbers.
In dash mount, 3 position, off, run, start, (spring return from start, 6 screw type terminals, and the current one is the longer shaft style.
Any help would be appreciated. And yes it does need replacing, this one is wiped out and doesn't return from the start position. Concerned that I'm going to end up damaging the starter eventually.
jerryjerry05
Re: Ignition Switch, 86 Bayliner/125hp Force
Temporary fix,spray WD-40 in the switch.
Then unhook the battery and try it a few times.
Spray some more,if needed.
SwampThing
Thanks for the responses guys. What I really needed was that part # F5H078 (for anyone else reading this). Think I'm going to go ahead and nab that one off ebay.
Yea I tried the WD40 fix without success.
Thanks again.
