Hello again. Fuel pump problem was fixed (earlier posts) but now, my ignition does not disengage when I turn the key off (and even remove it). To stop the motor from spinning, I had to remove the battery ground cable. When I even touch it to the ground post on the motor, it sparks and the starter engages despite the fact that the key is off. Is my ignition switch in the control box bad or could this be something else. Thanks, 75 HP, 77 Johnson Stinger outboard.
