Sacredgrooves
- Joined
- Jun 3, 2008
- 7
'99 stingray 4.3 mercruiser alpha 190 horse.
after running around all day, went to start the boat back up for one last tube ride.....nothing. all accessories worked fine so battery issues, but everything needing the ignition to power them up, basically gauges, were dead and of course no power to the starter. I pulled the fuse out and replaced it with another and it fired right up. IIRC fuses should not blow so there must be an underlying problem. Is the switch bad? anything else you can think of?
I am new to boats, do auto part chain stores carry basic marine parts too or do I need to hit a marine store?
one other question; the motor did a bit of dieseling, and I noticed the air filter was pretty dirty (it was in a gravel parking lot for a couple months) is it safe to assume a new air filter will correct my air/fuel mixture to end that? plugs, wires are all new. I did notice it only does it when I cut the motor right after a tubing run. maybe I should let it idle a bit?
thanks for any help! Dave
