Hi (again)...
The saga continues...
I was a sight to see yesterday morning, trying to hold the choke closed with my fishing net handle while starting the motor... eventually got her going and did some fishing.
I checked the choke solenoid with a hot lead and it's working. The push-to-choke function of the ignition switch is NOT working.
iBoats has several push-to-choke ignition switches and reasonable priced (compared to the actual switch for the Force), but I don't know which one to order. I know I can bypass the problem with a two pole push-button switch, but know that if part of the ignition switch is bad, the rest won't be far behind. I'd like to head those problems off ahead of time. So....
Any of you folks recommend a particular "generic" ignition switch with push-to-choke?
Thanks again, for ALL your help and encouragement.
steve
steve
