Ignition switch replacement
wndsfr68
I have a 1996 GW Invader Rivera that only seems to start when you turn the key and hit a "sweet spot". I starts every time but seems the key turns quite a bit before actually starting. Go to far and it sounds like it does when you have a dead battery. I think this ignition may have been changed at some point prior to me getting this boat.
Will any three position ignition switch work on this boat?
Other thread, sorry we didn't see it, just post again in it like "bump" to bring it back to the top
http://forums.iboats.com/forum/boat...5949-1996-gw-invader-rivera-ignition-question
For the most part yes, find one which looks like yours. Could have better luck finding one if we knew what motor you have
http://www.iboats.com/Boat-Parts-Ac...hed.1--session_id.679519987&q=ignition switch
Then any of the 3 position switches will work and don't get push to choke feature. Find one that looks like yours and can even get all brass to last longer
