Ignition Switch Wiring
gwetzell
I just purchased a 1986 Bayliner with a 1989 Evinrude 135. My question is the person put a new ignition switch on but did not hook up all the wires and I have no spark, power nothing. I was wondering if anyone can tell me what color wires go to what letterd terminals on the switch. Any help would be greatly appreciated. Thank you
Joe Reeves
Re: Ignition Switch Wiring
GWetzell.... What is the "Model" number of that Evinrude? OMC did not manufactuer a 135hp in 1989.<br /><br />Wiring harnesses have changed their colors somewhat through the years. What color are the wires leading from the wiring harness on yours?
gwetzell
The Model# on the motor is 135489B The Serial# is J0002689 the wire colors are Red with a Blue stripe, purple, purple with a white stripe, black, black with a yellow stripe, gray, white, brown. Any help would be appreciated.
Hooty
Your engine is a 1974 135 hp. Your best bet is get a manual for that engine. Clymer prints one and I believe you can get it through iboats. Click on "Manuals" at the top of this page. <br /><br />g'luck & c/6<br /><br />Hooty
Joe Reeves
GWetzell... Your engine is a 1974 135hp Evinrude.<br /><br />Red with a Blue stripe = "B"<br /><br />Purple = "A"<br /><br />Purple with a white stripe = "C"<br /><br />Black = "M"<br /><br />Black with a yellow stripe = (Raised) "M"<br /><br />Gray = Connects to tachometer<br /><br />White = "S"<br /><br />Brown = (Tan) = Connects to warning horn.<br /><br />NOTE... on some older ignition switches, there is no raised boss that the black/yellow wire attaches to. Those older switches simply have two (2) "M" terminals of the same appearance. On such a switch, it doesn't matter which "M" you connect the black/yellow wire to.
gwetzell
Thanks so much for the help with the ignition switch wiring, I got the switch hooked up properly. Gary
ZAX
WHY did you buy a boat with no spark >??
