I have a 1971 Chrysler 55HP. Battery ignition. Not magna. the old ignition has 6 terminals.
B has red wire hooked (battery circuit)
C has green wire (choke)
S has yellow wire (starting)
I has blue wire (to coils) When you turn key to start coil gets power
M has white wire (tach wire)
M has nothing
My diagram shows the above, so should my other M (empty one) have a white wire going to tach? I have mine set up as above except nothing going to either M terminals. I have white wire going directly to tach.
I ask because I need another switch and am going to get one with a longer shaft. So I can mount it. I have seem other ignition switch's with the , B, C, S, I terminal only. Can I use them since I do not use the M terminals on my switch? But my diagram for my motor does show the switch with the 2 M terminals. Seems to me they are only really being used on the 55's with magna ignitions.
Thanks
M has nothing
Thanks
