IGNITION SWITCH ?
MIKE COLLIER
My Tracker pontoon has been sitting idle for a couple of years and when I tried to start it the only thing that happened was the fuel gauge went to full plus. I'm thinking it's the ignition switch but I want someone else's thoughts. thanks
tlewis1
Might need a little more info...make/model of the engine...serial would be good too. What happens when the key is turned on..does the motor try and start...any clicking noises.....hows the battery..new...fully charged...connections?
If the fuel gauge moves, its not your ignition switch. Clean all your contacts
MIKE COLLIER
the motor is a 2005 mercury, 60 hp, four stroke, SN1B063517.............boat is 2005 Tracker Fishing Barge.................something more, the tilt switch has no effect and it should go with the ignition switch off..........the battery is full charged..........that's what I first thought was the problem.........thanks.........Mike
MIKE COLLIER
I stopped before I was through................I removed and reinstalled the battery connections...............when the switch is placed in the on position only the fuel gauge moves............."start" nothing happens...............fuel gauge shows full plus..........it pegs...............maybe I'm through this time
tlewis1
Take a wire brush or file and give the connections at the battery a good cleaning. The metal should be shiny. Do the other boat accessories work? Stereo/horn/etc.?
