Canman38
- Joined
- Jun 11, 2009
- 23
After searching for a while, I couldnt find an answer. So heres my issue; I am hooking up a pertronix on my 88 cobra 5.0 gm based engine. I have found lots of info on the install which has been very helpful. However, in trying to find a 12v source for the power to the ignition module I am getting thrown a curve ball. From every one I have seen people are hooking up to the purple wire on the alternator. So just to double check, I put a voltmeter on the purple wire, I am getting 11.1 volts. Thinking my battery might have been low, I checked its voltage..
I got 12.5v across the battery terminals.
I get 12.5v across the main battery cables.
I get 12.4v at the ignition switch.
I get 11.1v at the purple wire on the back of the alternator.
I get 11.1v at the coil positive.(which confused me,I thought there was a resistor there)
I get 11.4v on the purple wire to the esa module.
I get 12.5v at the tilt motor terminals.
All these numbers are with the engine off ignition switch on.
What do you guys get on your purple wire?
Do I have to wait for it to be running to see the voltages go normal?
I dont want to burn up my pertronix as people always say that, that is the reason the burn up, by not getting 12v.
Thanks in advance,
Walter
Thanks in advance,
Walter
