Ignition timing lead
jbutler67
1998 5.7L V8 (M048938)
2 bbl Mercarb
Thanks in advance for help on what some may find a silly question. New to Mercruiser engines and still learning. Appreciate all the great help on this forum.
Where is the ignition timing lead typically found? Is the other end of that purple/white wire connected to something on the block?
I see the purple/white wire from the ignition control module. I lose it once it goes into bundle or wrapped wires. The bundle of wires that come out by the alternator and electric fuel pump don’t include a purple/white wire.
Is the other end of that purple/white wire that runs to the ignition timing lead connected to something on the block? Or is it just a lead and is not connected to anything? (Hence the name.)
I found a purple/white wire with a female connector that isn’t connected to anything. The female connector has a rubber plug in it. I’m not sure if this is the ignition timing lead or a disconnected wire.
Is the ignition timing lead connected to something on the block?
Thanks
Bt Doctur
#2
click to enlarge
jbutler67
I have the diagram from the service manual.
3A is knock sensor
1D is the oil pressure sender
2D is the water temp sender
1C is the oil pressure switch
3C is the water temp switch
Etc
I can find where each of those are on the block.
2A is the timing lead. Where will I find this on the block? Is it connected to the block? Or a free wire available solely to set engine into base timing mode (not connected to anything)?
Thanks.
zealer
It is probably the one with that rubber plug in it. Usually found near the carb choke wires
jbutler67
Thanks.
So, it’s not connected to anything. It’s a free standing wire. Is that correct?
