Ignition timing marks mcm120 where?
merc120_81
I have 1981 Mercruiser 120 s/n 5828080.
I have found the timing scale mounted by the crank pully, but I see no harmonic balancer like on a car, and I can't seem to find any markings on the pully. I put a timing light on, and did not see any marking on the pully.
What is the "normal" mark on the pully, is there a notch, a line??
Engine is running decent now, but I want to replace the points and condenser as the boat is new to me, I have done the plugs rotor cap and wires.
Also, would poor spark/bad plug, contribute to overheating, I am still battling highspeed engine heat ups.
Thanks.
1981 Fourwins Marquis 170 Mercruiser 120
Don S
Re: Ignition timing marks mcm120 where?
The 120 don't have a vibration dampner, that's on the 140's.
There is a notch in the pulley. This picture should help you locate the mark in relation to the bolt holes.
merc120_81
Thanks, hopefully nobody filled it with paint. I will take a look.
Doernuth
When you find it fill it with a white grease pen. Makes it stand out under the timing light.
