kwoolard
- Joined
- Feb 9, 2003
- 420
I have been battling an overheating problem the entire summer. Check out the discussion: Engine Overheating <br /><br />I have tried everything except play with the timing. I have been reading up a little on that topic and have a few questions. First of all, without even checking the timing, I have no reason to believe that my engine is too far advanced. The engine doesn't knock under load. With my particular engine the cooling raw water is circulated through the exhaust manifold and back to the engine to help it get up to operating temperature quickly. However, my temperature keeps climbing passed the operating temperature. Therefore, I am leaning towards a retarded ignition timing. Meaning my exhaust manifolds are getting too hot because there is combustion during the exhaust stroke. A couple more reasons why I believe it is too retarded: when I remove the water line coming from the exhaust manifold back to the T-Stat housing the temperature drops dramatically, and another reason: the paint on my exhaust manifolds (right at the exhaust ports) turned from Ford blue to chalky white material two days of running after painting. <br /><br />My question is, how many degrees of retarding will cause the engine to run 30-40 degrees F over the proper temperature? Also, based on my observations, does this look like a retarded igntion timing problem?
