Ignition type?
OnagaCat
I have an '03 350 Mag MPI serial 0M354722 that has the PCM 555 module. Does this have Thunderbolt V ignition?
Thanks to all!!
achris
More fish than mountain goat
Re: Ignition type?
No. The ignition timing and mapping is done by the PCM555 module.... It uses information from the crank position sensor, coolant temperature sensor, Manifold pressure sensor, knock sensors and a few others to determine the best timing....
Chris......
Fun Times
Re: Ignition type?
No, it called a ECM 555 Ignition System.
Nicknamed Triple nickel.
