Just got my first boat, '79 Cobia Bowrider and it needed a little love. I have given it a lot of love and I am finally stuck. I had to replace the switches to the lights and the bilge pump (bilge pump too) because they were shot. The engine has an ignition problem too. So I figured that I would replace the old ignition with a new one. I am pretty sure that I did this correctly but the starter still wont run when I turn the key, choke will click though. The funny part was that I looked for the source of the problem all day one day and could not get it to start, unless I hot wired it on the back lug of the starter relay. It won't run the starter if I put the cable to the front lug where the battery cable comes in (Is that suppose to work that way?). This is on a 87 Force 50hp model C. And the next day I went out and it cranked right away. So I took it to the ramp and nothing. Jiggled the ignition and the battery connections and then it would turn the starter. Turned it off and then tried it again, nothing. Jiggled the ignition and battery again, but it didn't work this time. So I have no way of telling if I wired the new ignition correctly. Is this correct?
On the ignition we have:
B - Battery - Red
C - Choke - Green
I - Ignition - ?
M - Magneto - ?
S - Start - Yellow
M - Magneto - ?
I have a white magneto and a blue magneto and a black ground that I am unsure of which goes where. I hooked the ground to one magneto (as per instructions on the package), the white magento to the other magneto and the blue magneto wire to the ignition.
M - Black
M - Blue
I - White (Manual says this is the ignition side and the blue is the ground side)
I was pretty sure this would fix the problem if this is correct, but the problem still persists. The only thing between the Battery and the Starter are the wires and the starter relay. I know that everything else works such as neutral interlock because it did start a couple times with the key. Any suggestions on what to try next to get to the bottom of this? Could the starter relay be shot? Where should I measure voltage and with the key in which position to check if the relay is bad?
Thanks.
B - Battery - Red
C - Choke - Green
I - Ignition - ?
M - Magneto - ?
S - Start - Yellow
M - Magneto - ?
M - Black
M - Blue
Thanks.
