Ignition woes
Flipsy
I have an 85 evinrude xp 150. It’s been a work in progress. The boat sat for 9+ years. Last summer I drained the tanks, installed all new pickups. Took it out and it was a dog. This spring I got a fresh set of carbs. Installed them, did the full link up and set the timing. Took her out once again, ran like a champ! The following week we went for another outing. Wouldn’t start... upon further review of the engine I noticed a fragment of twisted metal in the flywheel. Seems that one of the magnets sheared and tore a piece off of one of the pickups on the stator. I had no spark on one bank of cylinders. After pulling the flywheel I found a large piece of the metal that was torn off. It was lodged in the stator. I have all new parts arriving soon. Stator, timer base and flywheel. Even bought magnets to rebuild my old flywheel, just to have a backup. Now here’s my question, should I be worried about the power pack? Could that rouge piece of metal have shorted it out? Or should I just put the beast back together, and give it a whirl?
F_R
Nah, that would be almost impossible (damaged power pack)
Flipsy
Ok 👍🏻. I’ll get it back together, and see how it goes. Thank you for the response.
Flipsy
Replaced the timer base, stator, and all new magnets in the flywheel. Put back together and I can’t get it to start. No spark on two cylinders.
Flipsy
Was able to get it running with a bit of starting fluid, but it sounds like one whole bank of cylinders is going in and out. Might just have to replace the power packs , coils and plug wires. Ugh
DRCrowe
FYI, you were probably on borrowed time with an 85' with original ignition. I have an 87' 225 and have replaced a couple power packs, magnets, stator and regulator. I consider it maintenance. You have a good motor and everything you have done is money well spent.
