Re: ignition
I apologize for any offense that may have been taken from my editorializing. I just felt that enough direction on other non-starter-y things to try was given. I feel your judgement of what to try first instead of those other steps could cost you more in the long run (or out on the water). The other methods did not involve any potential for mechanical abuse.
Now you need to help me, because my post#8 told you the pieces to find and fix based on results of the testing.....
From this latest description of what you did it seems to me you basically extended the feed wire at the oil pressure switch that had power all the way to the fuel pump and evidently that got power to the fuel pump. Does that accurately dsescribe what you just did?
If so, then did the engine start snd stay running that way?
You also stated you got no power to the fuel pump with the oil switch connections jumpered together. To me this shows bad wiring from the oil pressure switch to the fuel pump.
So then you still have two possibilities for fixing. The 1.) Oil pressure switch OR the 2.) Wiring from the oil pressure switch to the fuel pump.
First you need to find the wiring problem between the oil pressure switch and the fuel pump. Once you are certain that is fixed and it still does not get power at the fuel pump with the oil pressure switch hooked up then jumper the wires again, if that fixes the problem then you need to replace the oil pressure switch.
