We are doing two boats. The first one had excellent alignment before changing the gimbal bearing. After installing the new bearing, the alignment was off. Then I read here somewhere that we needed to put the alignment tool in and pull up, down etc. to adjust the bearing. We did that and something moved and all was well. At first movement, we were a little surprised and concerned. How could the bearing move if it's fitted tightly in it's bore?
The second boat had a slightly tight alignment fit from the beginning and after the new gimbal bearing it seems even tighter. I can see from the grease test that it's tight on the bottom. We tried to "adjust" this one with the alignment tool as with the first, but this one doesn't seem move. I guess this one needs the engine mounts adjusted?
