ok i have a 72 50 hp hydro electeric drive, ok at first i couldnt get it out of forward, yesterday i hooked up a 12v source to the lower end and it did shift, hooked it all back up today and everything seems to be workin fine , the original owner said that something was wrong with the lower end not shifting, well now it shifts, hmmm should i worry? i ran a test light almost the whole time and each time i had good power to the lower end. but i still have a few ?S i ran this motor for about 5 min on and off with the muffs, water coming from all kind of holes, guessing thats where they come from, but how do i know if the impeller is working, also is there a thermostat in this model? and one more thing its missing a toggle where the choke toggle goes but it does have a manual choke under the front of the motor, seems like it has 3 set positions all the way in 1/2 way and all the way out, now if i put this lever about 1/2 out between the middle and all the way out then it idles ok, push all the way in it revs to the moon, if u leave it at 1/2 still revs and all the way out it dies, so what should i do about that?
il probably have more ?S later when i think of them,
thanks for all the help
Jeremy
Jeremy
