I'm excited and I want to share with you and also say thanks!
SeaKaye12
Hi all,<br /><br />Well, I admit it's a small step...but today...after 27 years of non-use and total neglect...the 1977 Merc 850 that was recently given to me came back to life!<br /><br />I re-wired the internal wiring harness (it was toast) and I replaced the fuel lines.<br /><br />Today I went for it...hooked up the battery and connected the fuel line. At first, the top carb dribbled a bit...but then it seemed to stop.<br /><br />I turned the key...and after just three or four whines of the starter...she came to life!<br /><br />It even pumped water! With the original impeller!<br /><br />I had previously taken a cold compression test and got numbers from 166-170 on all four, so now that I know that it will actually fire up...I can feel better about investing in more maintenance...rebuilding the carbs and fuel pump, replacing the impeller and related O-rings...<br /><br />So thanks to so many people here who have answered my posts and communicated via e-mail. I'm sure that my questions are just starting!<br /><br />Here's a movie of the engine starting if you want to share in my joy!<br /><br /> http://www.russcamera.com/ebimages/DSCN0046.MOV <br /><br />Mind you...it's a 7MB file....<br /><br />Thanks again....Chuck
dakk1
Re: I'm excited and I want to share with you and also say thanks!
Chuck,<br /><br />Sounds pretty good after 27 years. I've owned 2 Mercs of that vintage. One was a 90hp, if I remember correctly (long time ago), and the other a 150hp. Both were darn good motors. Good luck..<br /><br />Dave..
joblo33
Nice engine!
