StangLX302
- Joined
- Jul 18, 2007
- 38
I've been doing a lot of reading on here and other forums about stainless props. Half of the info I've absorbed is that when choosing an SS prop, you should drop a pitch from whatever aluminum you were running because SS props do not flex and do not slip as much. Then, I've read that SS props have thinner blades and don't have as much drag as a comparably sized alum prop. By that logic, you would think RPM would go up.
So, by combining both things I've read. Both statements kind of cancel each other out and you should use the exact same pitch and size when switching to get the same WOT RPM.
Can someone with experience with this straighten me out here?
What I'm trying to figure out is that I'm running a 14.25 dia x 21 pitch Mercury Black Max aluminum prop. My WOT RPM is exactly 4800 RPM @ 43.9 MPH. This is exactly where this engine is supposed to run. I want to get an SS prop for more speed, but I don't want the WOT RPM to change at all.
