Impellar / Water Pump
dmgray55
Is it normal for the impellar / water pump to not pump enough water to cool the engine and stream out the weep hole when sitting in the driveway? When idling with a tub of water and all the intake holes covered by the water the over heat alarm eventually goes off within a few minutes. My impellar should be good as it has very few hours on it. I am tempted to go ahead and put it in the lake where I can throttle up in gear and hopefully be OK. Is this a good idea?
jgelsthorpe
Re: Impellar / Water Pump
i would check the sensor first if it is ok then no i would keep it parked in drive way because you have a heating problem . check thermostat.
jgelsthorpe
check t-stat in pan of water and temp gauge or thermo if it opens at desired temp the ok , but more then likly it is bad if you pumping a good stream of water but take it for what it is worth , but i would not chance on blowing up engine . it cheaper to fix the overheating problem . no motor cost money and then you have to put more money in a new motor to make it right
foodfisher
It probably was not deep enough in a tub of water. The pump sits higher than the inlet holes and won't suck up the water. Might have burned the impeller
Dave K.
yes it is normal on my 84, 85hp. i questioned that several years ago, burned my impeller out. i Never start my motor unless the lower is under water. look up overheating on this page. tons of info on early force impeller/housing issues.
