Re: Impeller - 1960 Johnson
Matt... Have the lower unit in reverse so that when you turn the propeller, the drive shaft will turn in the proper (clockwise) direction.<br /><br />Coat the two water tube gromments with grease. The water tubes should not give you a problem as they are close together and should just about fall into the grommets of the water pump.<br /><br />The thought crossed my mind that you might have those tubes inserted into the water pump and are trying to get them into the upper holes of the exhaust housing? If so, remove the tubes from the pump and manually insert them into the upper grommets within the exhaust housing so that they are up within the housing awaiting the water pump.<br /><br />Now, Have the engines shift handle in foward so that it doesn't interfere with anything as you push the lower unit upwards. Have the lower unit in reverse as stated earlier.<br /><br />Keeping the lower unit straight, not tilted one way or the other (forward, back, sideways) slide the lower unit up, guiding the water tubes into the pump grommets. Usually the driveshaft splines dont match perfectly and this is the reason for having the lower unit in gear. Turn the prop slowly which in turn is rotating the driveshaft so that the driveshaft splines slide into the crankshaft splines.<br /><br />The rest of the procedure should be no problem, but if one exists, we're here.
