I am going to have to replace my impeller soon on my 97 5.7 mercruiser.
but I am trying to find out whether or not I have a 1 or 2 peice pump.
That's a Gen II... The impeller part number is 47-43026T2 and looks like this....![]()
You should also replace the 2 gaskets. #27-430331 and #27-8172771.
This is the one you DON'T WANT..the older type (for the Gen I drives) and it looks like this....![]()
Chris......
Hmmmm,... Both of your little red Xs look exactly the same,..![]()
???????????????? Wow, I am way late on this one :redface:
I have been looking in the Mercruiser Service Manual #17 that I downloaded off here. So I have been looking at the wrong one all this time? Thanks for the part #'s btw. Does Sierra have a part #? Also, the impeller i want to replace is the one in the engine pump not outdrive right.
I just looked up the part number you gave me and that is the impeller for the outdrive. I am looking for the one that goes in the coolant pump on the motor.
Service manual #14 section 3B covers your drive and the raw water pump.
Not if he has a Bravo style engine-mounted seawater pick up pump. That's in manual #17...
How does one tell what kind of pump they have? I have an engine mounted pump for the raw side of my closed cooling. My boat is a 1978, but it has an Alpha one first gen on it. I do know the boat was ordered with closed cooling, so that should be covered in the engine manual for it?
Sorry, was thinking out loud there. :redface:
What i am wondering is if I can just drop the bottom of the lower unit without romoving the entire outdrive?
