Do I need to put grease on the drive shaft seals above and below water pump housing? Where the seal actually contacts the drive shaft. Also do I need to put any type of sealant or grease on the Inlet waterline seal (that attaches to the water pump housing) This is the seal that the water actually goes thru from the water pump.
