impeller help please
conron
changing impeller and to install new one it looks like it will be extremely tight to the point where the rubber blades will be bent..is this correct? Alpha one outdrive from 86
Don S
Re: impeller help please
The bent vanes is what makes it a pump. and yes, it's normal.
Just lube the impeller with some dish washing liquid and rotate the shaft clockwise and you push the what pump housing onto the impeller.
conron
than you Don. you have helped me so many times already I feel like I should send you a check
Fishermark
Maybe try :
General Delivery
Don S
Ocean Shores, WA
If that doesn't work, just send me the money and maybe I can get it to him. :D
Don S
Just PM me your credit card number, I'll only take as much as I need ........... :eek: :eek:
Just Kidding...:p :p
