Impeller housing/ Merc 25hp 1986
fishndvm
When attempting to put a new impeller into this newly acquired 1986 25XD recently, I noticed after the job was essentially done that there was a small gap between the bottom of the housing and the face plate along one edge. On the opposite side the two came nicely together. When I looked at it more closely, I realized that the housing consists of the dome proper, and a "cup" that sits inside it that accepts the impeller. It was soon evident that the "cup" was not level with the dome that it sits in. Perhaps better explained, if you had two bowls of nearly the same diameter, and you took one bowl and placed it on top of the other, and the top bowl's lip jutted just above the lip of the bowl beneath it, you could level the top bowl relative to the one beneath it, having the amount of lip jutting up the same distance all around the perimeter. On the other hand, you could also offset the top bowl whereby one edge of the top bowl could be nearly flush with the corresponding edge of the botom bowl, and that would cause the opposite side to jut up over the corresponding edge of the bottom bowl. That is essentially the situation with this impeller housing. That's why when you bolt it down to the faceplate, it's flush on one edge and forms a gap on the opposite side. A defect? Well, I bought another housing today, and guess what? It is exactly the same as the one I deemed defective. Offset just the same, and in exactly the same place. I don't get it. There is an O ring type gasket that fills the seam between the inner "cup" and the top piece of the housing, but it is clear that when the housing gets bolted over the face plate, the tension on the seal is not equal around the perimeter. It also results in the impeller being just slightly cocked, not level. Is this normal? Any help or advice would be appreciated. By the way, can Mercury somehow be called directly with technical questions? Anybody have a number? Thanks a million.
DHPMARINE
Re: Impeller housing/ Merc 25hp 1986
I think you'll find the inner bowl has a raised tab that needs to be aligned with the outer bowl.<br /><br />DHP
fishndvm
Hey DHP,<br /> Thanks for the reply. It started to look hopeless there for a while. I'm not really sure what it is you're trying to tell me. The housing, although sort of two separate pieces as I described, is still one solid unit. It's as if the bowl which harbors the impeller is solidly welded to the outer housing. It cannot be moved of adjusted in any way. And the housing can only be bolted down one way. Because the inner bowl is slightly cocked, When it sits flush onto the face plate, the outer housing, the part that actually bolts to the plate, sits flush to the plate on one side, and is slightly raised off the plate on the opposite side. When bolted down, it crimps the ends flush to the plate where the bolts are, but it leaves a slight bow in the middle. This just doesn't seem right to me, but again, both the old part and the new part are designed exactly the same. Maybe that's the way it's supposed to be, but I don't think so, and I'm stumped.
DHPMARINE
I looked deeper,as I should have in the first place.I thought your pump had a plastic housing with a stainless steel insert.You don,t.<br /><br />Your pump housing is ALL stainless,one piece,welded.Sounds like it is bad.Are you comparing it to a new one in this post ?<br /><br />DHP
fishndvm
DHP<br /> Yes, the new one looks exactly like the old one,. The "insert" is not welded to the housing on a level plane it appears. One would think that the insert would be welded to the housing in such a way as to have it's bottom rim level and even with the outer housing's bottom, so that when the unit is placed on the faceplate, they all sit there evenly, and when bolted down via the mounting holes in the housing, you get a nice even seal. This not only doesn't happen, but the offset insert is lined up the same way on both the new and the old units. Could they both actually be screwed up the sme way and in the same position? From that standpoint, it seems as if it was meant to be. From the standpoint of how it actually looks when mounted, it looks like a flaw. I just wish that I could talk to someone from the parent company and just run it by someone. I don't know how to make that contact however. Any suggestions? By the way, I really appreciate your input on this.
