Impeller housing OK
BlowHo
Is this housing OK. It looks oblong instead of round like I was expecting. Is this shape normal or do I need a new housing?
Thanks
BlowHo
Re: Impeller housing OK
oops! says the picture is too big. How do I resize to make this work?
HA! Got it to work!
HT32BSX115
Bill,
Oblong is correct (that's how it works) pull the impeller out of the housing to make sure it's ok. I have a used but good impeller you can have if you want it.........the housing and other stuff are fairly cheap to replace if needed though....pick one up from NAPA for a spare. One of the cool things about the Cobra is the ability to replace the whole pump without removing/disassembling the drive.
In fact you can get the whole KIT here But.. NAPA is easier & they can get it in 1 day.
I sold the engine!!
Did the starter work ok?
Cheers,
Rick
Windykid
It looks to be out of its normal shape replace or macth it up with a new one at the marina.
