I noticed that this part is missing on my '85 25hp. What are the effects of running without it?
T Trickle56 Seaman Apprentice Joined May 4, 2010 Messages 43 Mar 2, 2012 #1 I noticed that this part is missing on my '85 25hp. What are the effects of running without it?
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Mar 2, 2012 #2 Re: Impeller housing spacer Got a part # ?? Go to shop.evinrude.com and find one. Then we'll know more.
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,226 Mar 2, 2012 #3 Re: Impeller housing spacer If the spacer is missing, water will blow up the drive shaft tube, and cause rusting of the crankshaft and seal at the top. You need it in there.
T Trickle56 Seaman Apprentice Joined May 4, 2010 Messages 43 Mar 2, 2012 #4 Re: Impeller housing spacer Part # 326692 Thanks F_R
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Mar 2, 2012 #5 Re: Impeller housing spacer Now that I seen what spacer you're talking about, Yes it has to be in there as F_R said.
