Impeller install
JOHN12
Installing impeller in 20 hp merc 79-81,.
Is the impeller so tight in the pump body it "bends" the vanes a whole lot?
Also I assume the vanes are to be "bent" in direction of motor shaft rotation "duh".
thanks
John12
hkeiner
Re: Impeller install
Yes, they are bent quite a bit when installed.
I assume the vanes are to be "bent" in direction of motor shaft rotation.
I would not say that they should be "bent in the direction of motor shaft rotation." I would literally interpret that to mean that the vanes are pointed in the direction of rotation, which is not the correct way to install the impeller. I would say it another way, which is that the vanes should be bent so that the vanes ends are dragged rather than pushed when the shaft turns. I hope this is clearer. Others on this forum may have a better way to explain this.
The vanes would probably correct themselves anyway once the motor is turned over with the starter, but you can't count on that...
bgbass.1
when you are looking at it in the cup the vanes should be facing clock wise
