shute421 said:I was looking to see if anyone knew how hard it is to install a new impeller on my 88 Volvo 140hp??? What exactly needs to happen??
Don said:Volvo does't go by year, and usually not by HP, so, what's your engine model number?
Don said:Remove the 4 screws holding the cover on. Pry the impeller out of the pump body with a couple of screwdrives. (Make sure the shaft does not pull out of the pump). Put some dish washing liquid on the new impeller and twist it into the pump housing. Install cover with new gasket/oring (whichever it has).
You can also download a free owners manual from Volvo at the link below.
http://www.volvo.com/volvopenta/global/en-gb/marineengines/operators_manual/operators_manual.htm
Don said:No easy way, you have to either pull the exhaust manifold, or lift the engine up and forward.
b00tstrap said:shute421
No offense here, but take the time to do some research on the work you want to perform on your boat, it will benefit you and the boat greatly![]()
