Impeller issues?? 15 hp 4 stroke Evinrude
weebojc
I am not getting any water coming out of my spout that should be ejecting water when running my motor with the muffs hooked up to it full stream of water from hose.
As suggested, by Bankerjohn in another post, I put a length of trim wire from my weedeater in the spout and pushed and prodded around, but to no avail. I then figured I would drop the lower end and take a look at the impeller, but was unable to get the bottom end off after removing the 6 bolts that seem to keep it tightened to the top part of the motor. Any ideas or suggestions here folks?
Thanks,
Jamie :)
bankerjohn
Re: Impeller issues?? 15 hp 4 stroke Evinrude
Before you remove the 6 bolts, you need to:
  • Remove shift connector clip from shift lever.
  • Remove shift connector from shift lever. Unscrew connector from shift rod.
If you're going to tackle this kind of project, you really need to purchase a factory service manual ... it's worth its weight in gold!
weebojc
Why couldn't you just tell me to pour a whiskey and wave a wand instead?
Damn.
Thanks Bankerjohn. I'll have to pick one up next time I run into the city.
Jamie
