Impeller not pumping out any water
corbin5754
Just had a mechanic install a new impeller on my 88 evinrude xp 150 because the old one wasnt pumping out any water but after he installed new impeller it still wont pump out any water thru the outlet tube do i need to buy a impeller repair kit off this site is that my best bet. also when he took off the housing 2 bolts broke but he told me it would work fine without those, with the other to bolts tightened.
mrcj001
Re: Impeller not pumping out any water
The water pump Could be pumping but not coming from the pee hole...check the pee hole for clogging or restrictions in the water jackets. If that checks out, the impeller may not be seated on the shaft key correctly.
Johndhii
No offense, but you may want to get an easy out for the other two bolts
corbin5754
if all that checks good could it be the thermostat.
Sixmark
What, kind of mechanic did you take it to, if he replaced it and it still doesn't work then he didn't complete the job, not to mention that any mechanic worth his weight in salt wont just say "oh those 2 broken bolts are fine".
If 2 of the 4 bolts on the housing are broken then water can very well leak out of the housing therefore not creating enough pressure to even get the water up the tube to the motor. It can also cause the shaft to ride improperly in the housing and tear up the seal....again creating a leak.
The other thing to look for is that the tube is properly seated into the housing. If you took this to a legit mechanic then you should be taking it back to him and telling him to get it fixed.
corbin5754
hes coming back friday to fix it we never checked it after the install cause he was also cleaning my carbs and it started getting dark and raining. but after we do all those and it still wont work could a thermostat change be the problem.
MGoral
Get yourself a real mechanic, get those bolts replaced that are broken. Have your next mechanic inspect the work, sounds like the water pump wasnt installed correctly. Good luck!
corbin5754
right on guys thanks for the help.
corbin5754
Ok I pulled lower unit off heated up those broken bolts and got them out. I ordered the waterpump repair kit since I got unit out and its 23 yrs old. Should I replace the thermostats. I looked at 1 and it had **** growing on it lol. I never new it had thermostats cause I had the impression that water always circulated thru the engine from the impeller pumping it
Sixmark
If they look corroded then replace them, especially since you said it hasn't been done in 20 years.
corbin5754
I did I replaced everything kit came with new bolts
corbin5754
I also replaced my thermostats they were clogged with tiny sea shells. I also sprayed seafoam into my carbs man did a lot of junk come out my grass is black all around the prop. Do I need to replace plugs after a decarb...
mark1961
Ensign
The thermostats ensure the motor runs at its optimum temp, without them it would likely run "cold" all the time causing rough running and premature wear, they also play a large part in ensuring the water supply from the pump reaches the top of the powerhead.....
corbin5754
Right on guys all help is very appricated
emdsapmgr
You stated you had debris in the thermostat housing. That housing is the last thing the cooling water goes through before it exits into the midsection. That means the debris in the thermostat housing got there by circulating through the entire engine before they lodged in the stats. You want to do some further investigation. There may have similar debris in the heads. I'd pull the head covers (not the heads) and see if there is debris restricting the water passages there. If you find anything significant, you may also want to pull the heads and check the water passages around the cylinders-esp the rubber water diverters.
corbin5754
Would you do all that if water was coming out strong from the pee hole
emdsapmgr
The outlet for the telltale is upstream of the heads and cylinders. You can have a strong telltale and still have a blockage in the powerhead
corbin5754
Checked um they looked good no shells lol.
