I have been on here lately with differant problems, and first of all thanks to all that has replied. A new problem now. Motor is 1962 40 h.p. evinrude, electric shift model # 35933. I replaced the elctro magnets in the lower unit and everything there is now fine with the gears. Last week's test run, I had very good water flow with a new impeller AND new impeller housing, but I got water in the gear case. Re-did that now with new o-ring there and I put everything together, and I cannot get water to pump through the impeller any longer.
New impeller and housing, new grommets, tubes are good and facing correct way. Impeller started pumping a little bit. Took it back apart and found four impeller venes facing wrong way. I know I put them in right, how can they flip and face the wrong way?? I put the impeller back in, it started pumping again and quit. I took it apart and vanes are facing wrong way. Checked out ompeller against a differant new one at the marine parts dealer and the impeller and housing are the right ones. Now I put it back together and it will not pump at all. The water passages are clear, the impeller is new, the housing is new, what could the problem be??? Thanks again all!
