impeller or no impeller on freshwater cooled
rmcustoms
hello all, need some help. i have a 1985 26ft harborcraft with 260hp 350 and alpha one gen 1 drive. the boat is freshwater cooled.(has a water pickup on the transom) just boat a new lower unit for the boat. question i have is.... do i still need the impeller in the lower unit or do i need to remove it?
Bt Doctur
The water pulled thru the drive by the impeller helps cool the drive`s oil, so leave the impeller and cut the hose
rmcustoms
so, does the water just stay in the lower unit or will it fill into the boat somehow?
Bt Doctur
That tells me you have a heat exchanger and the motor uses regular A/F for the coolant . If it is a 1/2 system, the impeller in the drive is needed for the raw water to get into the heat exchanger(HX). If the motor is a full system, engine and manifolds then it needs an engine mounted raw water pump and a thru hull fitting.
What system do you have?
