Impeller part needed for 1949 4hp Scott Atwater
Outboard Mike
Trying to find an impeller part number for a 49 4hp Scott Atwater Serial# 491-500339. It is a single impeller(not bail-o-matic) and is the same as a Firestone for the same year. Is there a similar impeller that can be converted?? The inside Diameter is 1/2 and the vanes are another 5/8in on each side for an outside diameter of 1 3/4in based on the old one that was on the motor. I think the Mercury impellers are the closest to the type. Any ideas on potential conversions from newer impellers would be greatly appreciated.
Thanks,
Mike
steelespike
Re: Impeller part needed for 1949 4hp Scott Atwater
If you go to www.aomci.org there may be someone making impellers or that knows a substitute.
torbjorn
Thanks,
Mike
Some Scott parts are available from:
http://www.scottatwaterinfo.com/
http://www.laingsoutboards.com/
Failing that, I have a private connection but he deals mainly in 1957- McCulloch Scotts.
1946Zephyr
I dealt with a gentleman in the AOMCI who specializes in Scott parts. He should still be there. But yea, give the AOMCI website a try. You should be able to hook up with him.
tmcalavy
brian wilcox can make one, google his name.
