I installed a new impeller in my 9.9 HP, 1965 Mercury boat motor. The first time I started it water only came out of the small hole on the side. I then cleaned out the water exhaust manifold channel.
When I started the motor the next time water came out of the small hole on the side and it would pee out the big hole (there was not a lot of water coming out. The next time I started the motor it quit peeing. I took the lower unit off to recheck the impeller and it looks ok. I used a water hose, water came out of the pee hole and the small hole on the side.
What do I need to do now it will pee when I first start it then it quits. The next time the motor may start peeing or it may not (Interment). What could the problem be that it does not pee like it should?
Could it be the new impeller? I do not thank there is any type of blockage in the water passage ways.
i have been using a 55gallon water barrel . i do not know if this has any thing to do with it but after runing the motor there was a grease film in the barrel.
