Impeller pump base V6.Confusion.
aussieflash
Gday all.
Pulled my water pump for service and decided to yank out the base as well.Have I pulled this thing apart in 2 pieces?Should i leave the blue disc shape seal in or try and get it out.
Also as you can see ive cleaned up paint surface where it meets with mid section.anyone know if i should prime before marine enamel.
Thanks Paul.
Faztbullet
Re: Impeller pump base V6.Confusion.
It came apart which is not unusual,walk the lower piece out and reassemble....
