water should be present in the system as high as the surface of the lake water
therefore, yes, the pump mounted on the engine is below the waterline - it should have water in it, no need for it to "self-prime" with the boat in the water
take the pump apart and make sure the impeller is in good condition - with a new impeller, the pump should have enough suction to pull water into it and supply the t-stat housing with water
