Re: Impeller Replacement Instructions
You have to pull the powerhead to disconnect the shift rod before you can get the lower unit off to replace the water pump. When you get the powerhead off, you will find a carbon seal with a spring under it. Pay particular attention to how it goes. When you put it back together, replace the 303355 cork-like gasket on the seal plate, and the 303347 o-ring in the carbon seal. It is VITAL that you do that. You will also need a new powerhead gasket. Glue the 303355 to the plate with some gasket cement.
