I replaced the empeller and put new gaskets for water pump..
My question is When i put the upper an lower back together
I was under the impresion i had gotten most of the lube out.
but when i stuck the top unit back on the bottom some lube seemed to come out
This sounds dirty. anyway is this normal for a bit of lube to leak?
