PurpleDragon
- Joined
- Nov 11, 2001
- 124
Whew.. I was sweating there, while iboats.com was down for the morning... I was having withdrawal symtoms!<br /><br />I've got a 12hp Sears Motor (West Bend) - circa - 1965. The impeller has never been changed - and whoo-hoo I've found a replacememt and had it shipped to me.<br /><br />The lower unit came off without a hitch. But now the bolts holding the impeller housing are being a pain in the rear to remove. I've hit them with a shot of Kroil. Should I just let-em sit? Or try some other means of loosening the bolts? (apply heat?, or just let it sit with Kroil on it for a while, and try later?)<br /><br />To make this an easier chore next time around, would there be any problem with replacing the "flat-head screwdriver head bolts" with hex bolts so that I can use a socket next time?<br /><br />Thanks,<br />Rex S
